![]() | Home > General > Suspension fault |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
http://www.rrsport.co.uk/forum/topic29759.html
harryp Member Since: 21 Jan 2014 Location: yorkshire Posts: 8 ![]() ![]() ![]() |
Thanks Nick but not sure that it helps, as I cannot clear the code in order to try raising and lowering suspension.
Mattmsm Member Since: 19 Jan 2014 Location: Notts Posts: 4 ![]() ![]() ![]() |
Hi Harryp I'm new here too but not new to sports either. What diagnostics scanner have they used on it as it would be 7 digit fault code if it was SDD/IDS.You have an issue somewhere as invalid data codes usually clear with no problem if the fault has been rectified.
Thanks Matt. Not sure what diagnostic scanner they used (also not sure what SDD/IDS means - please excuse my ignorance), but thought U0434 was a valid code.
You mentioned that they did a recalibration why, if they just changed the bag as there is no need to do it, you get this fault if the calibration is out of limits as well.. Look at your 4x4 screen and check all the height sensors to see if one is showing any faults..
Hi Ian SDD is symptom driven diagnostics and what the dealerships use.IDS is the legacy version of it that was used before SDD in dealerships.
Thanks Flack. 4x4 screen shows all ok and measurements look ok too.
Hi Ian If it is the wiring the repair kit is available from the dealers it consists of a new plug with about a foot of wire attached so it's basically a case of cutting the old plug off and solder the corresponding wires together so not the most technical job just ensure you insulate the wiring well to keep the wet out.I will post up the part number in the morning as I have one at work
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Depending upon what diagnostics they have, it may as simple as they could not clear the codes in the DRM, which is causing the air suspension light to come on with the lost comms error.
Thanks again Matt and thanks Mikey.
Doesn't the 4x4 info screen show a red bar over a wheel with a faulty height sensor? Think this is correct but I've not had that problem (yet).
Thanks Paddi, fortunately I do not have any red lines over the wheels so hopefully sensors are ok.
kozzone Member Since: 26 Feb 2015 Location: Vaasa Posts: 21 ![]() ![]() ![]() |
Hi
