Home > Technical > parking sensors
mark.b
2007 Range Rover Sport TDV8 HSE Stornoway Grey
parking sensors
Hi all I'm hoping someone might know why my front sensors are not working when the rear one are fine i have a 2007 tdv8 hse
mark
Post #409677 Wed Jan 15 2014 8:32pm
PEACHY
How do you know the rear ones are fine ?? 16MY Estoril Blue SVR.............
Post #409678 Wed Jan 15 2014 8:40pm
PEACHY
Do you still get the bleep? one long continuous bleep ? with the error message ? Front parking aid inactive ? common fault - the sensors don't last forever - if you get the bleep - it's a sensor. Ideally you need a diagnostic tool to read the codes this can identify the offending sensor location. Mine used to dry out therefore work & then stop when it rained causing intermittent problems.
Hope that helps Thumbs Up 16MY Estoril Blue SVR.............
Post #409679 Wed Jan 15 2014 8:45pm
rigsby
Are they turned on ??? I believe they can be turned off on the dash, check the button MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #409688 Wed Jan 15 2014 9:12pm
mark.b
the rear ons bleep as they should when you get closer to a fixed item one continuos tone but the from are dead nothing i have checked to see if the wife had turned them off at the dash switch and no she hadn't looks like a trip to the steelers to get diagnostic checked Big Cry
mark
Post #409691 Wed Jan 15 2014 9:21pm
PEACHY
So there's not even a message on the IP Question 16MY Estoril Blue SVR.............
Post #409693 Wed Jan 15 2014 9:26pm
mark.b
no peachy no message at all mate
Post #409705 Wed Jan 15 2014 10:07pm
PEACHY
Have a quick look at this may give a little help Crying or Very sad same principles apply Thumbs Up
Post #409712 Wed Jan 15 2014 10:37pm
Grimps42
England 2005 Range Rover Sport Supercharged HSE Rimini Red
Mark
Just been through this process with mine, I had front parking aid inactive I am fortunate that I have access to a diagnostics machine and the fault I had was a faulty sensor sounder which is located near side boot behind panel you will see the control module and the sounder they cost 20.00 from dealer, replaced sounder all errors went and now works fine,
My symptoms were identical to yours continuous bleep then inactive message,
Good luck hope this helps
Post #410411 Mon Jan 20 2014 10:49pm
