| RRSPORT.CO.UK | ||
|  | Home > Technical > Access mode height measurements |
| LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75    | lol ok so no measurements I take it then,
|  Wed Jan 15 2014 10:49am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | This id the height they should be in "Normal" mode.
|  Wed Jan 15 2014 10:56am |
| LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75    | Hi, thanks for the reply, ive seen that and in normal mode it sits level, its in access mode its not level, that's why I want the measurement to see if its the front to low or rear to high.. | ||
|  Wed Jan 15 2014 11:04am |
| rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879    | Hi Locust, just had a measure for you and my front wheel arch is 775 mm from the floor measured through the wheel centre and the rears are 788 mm. Got some time this afternoon so if you want any other measurements let me know, regards rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
|  Wed Jan 15 2014 1:58pm |
| LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75    | you sir, are a legend !!! range is at home so will check this out later when im home | ||
|  Wed Jan 15 2014 2:34pm |
| Posting Rules
