Home > Wheels & Tyres > Alloy wheel corrosion
duncs321
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Chawton White
Hi, I have a 2013 RRS, old style. When cleaning my car this wknd it was like a surface rust had appeared on the wheels. Wonder wheels would not remove this. It took a brilo pad and a lot of elbow grease to remove.
Is this the start of corrosion on the wheels? I have never had to scrub alloys to clean them like that before, it's like a protection coat is missing? Anyone any ideas? Back to the dealer?
Post #409409 Mon Jan 13 2014 10:54pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
What style of wheels do you have? and are they diamond turned? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #409412 Mon Jan 13 2014 10:57pm
duncs321
They are standard 20" wheels, came with the car, not diamond turned.
Thanks
Post #409413 Mon Jan 13 2014 11:00pm
My advice on the first instance is ditch the wonder wheels and the Brillo pad, way to harsh for the wheels and I wouldn't tell the dealer that's what been used either Wink
From what you're saying, it doesn't sound right. Are they silver painted or diamond cut? If the latter, it could be that they have become corroded.
Pay the dealer a visit and see what they have to say. You're well within the guarantee, so hopefully you'll get it sorted. Thumbs Up ON THE WAY: BMW F21 M140i
Post #409415 Mon Jan 13 2014 11:04pm
duncs321
Yeah did think the brilo was harsh, only thing that would remove the surface rust. It's all off now so will just have to wait and see if it comes back... I have a feeling it will, they are not diamond cut.
Thanks
Post #409417 Mon Jan 13 2014 11:08pm
Paddi
Its my guess what you could see was very hard baked on brake pad debris. The RRS brakes have to work hard and even after the shortest trips you'll find brake debris on the wheels - was it a long time since you last cleaned them? Have they ever been sealed with a hard wax?
The Brillo pad catastrophic mistake will have severely scored the lacquer on the surface. You should have used Iron X which magically dissolves brake debris in a few minutes. The only way to save your wheels now would probably be to use Iron X then polish up the scratched lacquered surface with something like G3 and apply a hard wax or sealer. If you leave them as they are the brake debris will stick to them even harder. If you don't have the inclination to do it yourself take it to a good detailer. They can work wonders. Thumbs Up 2008 MY Java Black TDV8 HSE
Post #409483 Tue Jan 14 2014 2:57pm
brilo pads should be kept in the kitchen sink not in the car cleaning cupboard Shocked
Wonder wheels, used occasionally is ok IMO, but iron X or Wolfs Deironiser is the way i go when doing a deep clean, in between I use Wolf Chemicals Clean and Seal, cleans then break dust off and leaves little nano sealers behind when you rinse it off
Post #409497 Tue Jan 14 2014 5:34pm
duncs321
Thanks for that
Post #409534 Tue Jan 14 2014 9:49pm
MXSRR
England 2007 Range Rover Sport TDV8 HSE Sumatra Black
Thanks
Can you post a pic to show the corrosion? MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's
Post #409581 Wed Jan 15 2014 9:30am
duncs321
The brilo removed it all. If it comes back I will post a photo..
Post #409613 Wed Jan 15 2014 1:31pm
duncs321
Thanks for the iron x recommendation, it is brilliant stuff.
Post #410564 Tue Jan 21 2014 10:17pm
^^^ It's a great product.
I used this a lot, but have recently changed to Bilt Hamber Korrosol as it works out slightly cheaper and is marginally better IMHO. Smile ON THE WAY: BMW F21 M140i
Post #410622 Wed Jan 22 2014 8:56am
