![]() | Home > Maintenance & Modifications > 105k maintenance |
| tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917
if you're referring to the cam belt and oil pump housing, it'll probably be more expensive by not having them done. and think about the re-sale value |
| stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120
Thanks for your help, It was the cam belt have you any idea of cost, Thanks Steve |
It depends what you have been told that needs doing. If you have been told that you need the cambelt replacing, then you have been given the correct information, and yes you really do need it doing or face the risk of destroying your engine if its not replaced and your old one snaps. |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
All service plans are suggestions which you can ignore.
one thing i've heard through this forum is that the cost can be lessened if you source the parts yourself, e.g through one of the site sponsors, then pass these on to the lr garage or indie for fitting. or you could do the entire job yourself, if you dare. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Thanks all for your help, I have not been told that the work needs to be done by a garage just a lad in the pub told me about it, tanloverluke thanks for that, I just about know how to drive and were the fuel goes so i think i will start saving up and let the garage do it. |
