Home > General > Battery Life
midsman
Battery Life
Hi all, I need some advice from a more technically minded RRS owner. I have a 62 plate RRS HSE Luxury with 14000 on the clock. When we bought it it had a flat battery and was started with a power pack. It has run without problem for 4 months. Left it in the garage for 11days over Christmas and came back to a flat battery. Called out Land Rover Assist who started the car. Their technician showed me the drain on the battery when you open doors etc, just the action I take when valeting it.They suggested that I purchase a smart charger and leave the car hooked up when not in use. We are infrequent users of the car so having it in the garage for 2 weeks is not unusual. It is primarily used for towing our caravan. My question is just how long should you be able to leave a RRS before it will not start?
Post #409130 Sat Jan 11 2014 5:43pm
simple1
Varies a lot. My used to be exactly the same, dead flat if parked for more than couple of weeks and it had done 5k a year roughly towing or odd day out. I had same battery for seven years but resorted to smart charger to make sure it started. Down side is you can't go away for more than two weeks if you leave it at the airport Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #409141 Sat Jan 11 2014 7:54pm
drdelrrs
If you really wanted to leave it for over two weeks you could try a solar charger left on dash.
Post #409162 Sat Jan 11 2014 10:24pm
mse
My sport lasted with no problems for periods of time. We definitely left it for 2 weeks (+ a few days either side) on holiday once.
Once you kill a battery, it will never be the same. you can recondition them to a degree...but they will never be as happy. Mike
2014 Facelift Discovery
Post #409165 Sat Jan 11 2014 11:25pm
rigpig100
2008 Range Rover Sport TDV8 HST Santorini Black
well I had to bite the bullet today and had a new battery fitted today, they did test the alternator all good but 277 quid had me reeling !!
Post #409526 Tue Jan 14 2014 9:18pm
