Home > Technical > Front parking sensor aid inactive on dashboard
Grimps42
England 2005 Range Rover Sport Supercharged HSE Rimini Red
Hi everyone
I have recently bought a RRS SC 2005 68,000 miles everything was good until yesterday, I had the car washed and now today I have a message on dash at start up, front parking aid inactive? Also the rear sensors have stopped working also? I have seen a similar post with the exact same fault and sequence of events to how this happened but it was unclear how it was resolved?
Can anyone help? And can anyone point me in the most like direction?
One other thing?
One post indicated the front sensor loom controls the rear audio sounder for the rear sensors,? If the sounder speaker was u/s would this cause the problem?
one other thing prior to the parking sensors failing when the car was in reverse the rear sounder would be on continuos? which leads me to believe I may have had an intermittent fault with a rear sensor, if so would the message on the dash read front parking sensor inactive?
Any help appreciated
Post #408748 Wed Jan 08 2014 10:18pm
PEACHY
Welcome to the Forum - do you still get the bleep? one long continuous bleep ? with the error message ? .Common fault - the sensors don't last forever - if you get the bleep - it's a sensor. Ideally you need a diagnostic tool to read the recent error codes this can identify the offending sensor location. Mine used to dry out therefore work & then stop when it rained Sad causing intermittent problems.
Hope this helps Thumbs Up 16MY Estoril Blue SVR.............
Post #408753 Wed Jan 08 2014 10:37pm
Grimps42
Hi peachy
No beeps what so ever, I have plugged in the diagnostics it did say something about the parking aid sensor control module fault we cleared it and the message still happened on start up? Where is the control module located? I can't seem to find it?
Post #408755 Wed Jan 08 2014 10:44pm
Grimps42
Chechen fuse 36, 5 amp fuse parking sensors it was good? Do the control module have separate fuses?
Post #408756 Wed Jan 08 2014 10:46pm
PEACHY
Try this Thumbs Up
Post #408757 Wed Jan 08 2014 10:53pm
simonj007
England 2007 Range Rover Sport Supercharged Zermatt Silver
Peachy is the best!!
Post #408971 Fri Jan 10 2014 3:39pm
fredouille
France 2005 Range Rover Sport TDV6 HSE Java Black
hello,
i had same issue, with FRONT aid parking desactivated message. (rear did not work also).
i changed rear audio sounder/buzzer (for few euros) and everything has been fixed!! Thumbs Up
fredouille.
Post #409086 Sat Jan 11 2014 9:01am
Grimps42
Thanks very much, just need to find the part number now?
Post #409089 Sat Jan 11 2014 9:41am
fredouille
LR006482 Thumbs Up
Post #409274 Sun Jan 12 2014 11:26pm
rumz
Hi All,
Sorry to resurrect an old thread but I have an issue with the rear pcd. Changed the buzzer and it was working for a few months. All sensors click. Upon starting the car the rear pcd works and after a while it then produces a continuous beep.
The light in the dash is fine as well.
What could be the issue now?
Post #467590 Wed Jul 15 2015 6:42pm
rumz
Anyone?
Post #467675 Thu Jul 16 2015 3:08pm
Lost for Words
A damaged/corroded loom would not be unlikely. Thumbs Up Visiting from DISCO3.CO.UK
Post #467677 Thu Jul 16 2015 3:21pm
rumz
Thanks mate,
I'll order a new one - still don't know why upon starting the car everytime it works perfectly but after driving for a it it fails Sad
Post #468128 Mon Jul 20 2015 9:45pm
