Home > Technical > Charging light on Dash
Black Bess
Apologies if this has been covered before, but the charging light (red battery symbol) has just come on on my 2005 2.7 diesel. I have not yet checked for charging, which is the obvious cause to persue, but I seem to remember reading recently that other systems can be marked by this warning light too. Does any one know if this is the case?
Thank you
Adam..
(Black Bess`s owner)
Post #408350 Mon Jan 06 2014 5:16pm
Bodsy
Site Sponsor
It will be the alternator. Get a new one from advanced factors and it's about 30 mins to change (v6) think the v8 is a bit more complicated. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #408381 Mon Jan 06 2014 8:23pm
fredouille
France 2005 Range Rover Sport TDV6 HSE Java Black
i agree, I had same result: alternator.
be prepared being out of power very soon. light appear on the evening while parking the car.
next moring i was able to start and drive 40km to reach a garage, then engine was unable to start again, battery fully discharged.
Post #408431 Mon Jan 06 2014 11:29pm
Black Bess
Thank you both for your advice.
Actually, the light came on on my way to work yesterday and went off as I returned home last night. I have seen this on other cars and I think it is putting me on notice of an impending failure. I will get a new unit lined up today. The car is approaching 100,000 miles, so not unreasonable, i suppose. I will be doing the cam belts too very shortly.
Thanks again
Adam..
Post #408463 Tue Jan 07 2014 10:04am
Might be worth getting the alternator checked before you shell out for a new one, but the signs are pointing towards a new one. Sad
Post #408489 Tue Jan 07 2014 11:57am
