![]() | Home > Maintenance & Modifications > Puddle Light problem |
| mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298
Since I got my Sport the puddle lights on the bottom of all four doors haven't lit when the door is opened. It never really bothered me until I decided to change my interior bulbs to LED’S after reading a few threads on the forum here. I just always assumed the bulbs must have went and hadn't been replaced. When I removed the old bulb on every door and stuck the new LED bulb in it lit no problem on each door....fine I thought, I must have been correct in my assumption, the old lights hadn't been replaced when blown.
Tried all four doors Ady, none of the puddle lights on them work.....but all did when i first inserted the new led's....then when I tried them all later, none worked and my boot light didn't light either....strange. |
| Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307
Have you checked the fuse? |
Never checked the fuse Paul....do you know what fuse it is and where the fuses are located? |
Try the lower glove box, once open you have to pull the inner edges of the glove box in towards each other then lower the box further. The fuses will be behind there. If in doubt refer to hand book to find the fuse number. |
Strangest thing Ady...wife was out in the car last night, when she came home reported that the puddle lights still were not coming on. I drove the car this morning and low and behold the puddle lights came on...tried all four doors and all came on.ok.....crazy. |
| All times are GMT |
