| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Changing bulbs? |
| mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298      |
 Changing some interior bulbs to leds.....Not too handy with a screwdriver to be honest....I have change two of the three bulbs (above the rearview mirror) successfully but the fitting for the centre one seems to have disapeared up into the trim when I took out the old bulb....Can anyone advise me the best way to retrieve the fitting...Will I have to take the entire trim off? How does it come off if so?....Advice much appreciated. 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
|  Sat Jan 04 2014 2:24pm |
| mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298      | Peachy I had a torch to look up inside but I can't see the   | ||
|  Sat Jan 04 2014 2:45pm |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Nothing but clips & the cables you need - stay away from the front & you will be ok   | ||
|  Sat Jan 04 2014 3:33pm |
| mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298      | Thanks peachy, going to have another try in the morning.  | ||
|  Sat Jan 04 2014 8:33pm |
| mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298      | Peachy I ended up taking the map light trim off (which for me was a major accomplishment in itself   | ||
|  Mon Jan 06 2014 12:50pm |
| Posting Rules
 it must have gone to either side, as I don't know whats up in there I didn't want to poke around too much incase I
 & I'm pretty sure the cables run from the right hand ( drivers side )
  & I'm pretty sure the cables run from the right hand ( drivers side )   ) The little light connector was inside I stuck it in the hole, gave it a twist to secure and the jobs a good un....all three leds fitted and working well.
