![]() | Home > Maintenance & Modifications > Suspension knocking....again!!! |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
Did your dealer changed bushes only
StuRRS Member Since: 18 Jan 2013 Location: Gloucestershire Posts: 92 ![]() ![]() |
Looks like just bushes- receipt says "BUSH - STABILIZER BAR LINK" 2 of these for the princely sum of £23.50 + vat
Try this drive the car at 10 to 15 mph and dab the foot brake hard quickly, if it knocks then you need lower arms changing, its a common fault on older cars...
Thanks Flack, just tried that and seems ok. Just getting the tell tale clonk on speed bumps and when moving the steering wheel side to side at slow speeds.
depending if the new bushes were fitted with old (read - non modified) clamps
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 ![]() ![]() ![]() |
My Stealer wants £185 per set plus labour works out at circa £1,200 are we talking about the same bushes? |
Rangeybath Member Since: 10 Dec 2013 Location: Bath Posts: 9 ![]() ![]() ![]() |
Have exactly the same problem with mine. Great thread folks - will go down the garage loaded with knowledge |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
£1200 sounds more like the cost of replacing the anti roll bar itself (assuming a dynamic response ARB is fitted). Either that or they're planning to split the vehicle in order to do the bushes - that's several hours of labour cost straightaway. As people have replaced the ARB bushes on their driveways, it would seem that splitting the vehicle to do them is somewhat excessive. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Sounds like that's the cost of replacing the front lower suspension arms. My dealer quoted me a very similar figure for lower arms. 2014 L405 SDV8 RR Autobiography ![]() 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone ![]() 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
I have so far;
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4478 ![]() ![]() ![]() |
Lower steering column |
Good news then ![]() ![]() 2023 RRS p440e SE Dynamic 2018 Discovery 5 SDV6 HSE Santorini gone 2014 SDV6 HSE Santorini gone 2007 TDV6 HSE Java gone 2003 Discovery TD5 ES gone and missed 2008 Q7 gone 2005 X5 gone 2003 X5 gone 2000 Freelander 2.5 V6 gone- not missed!! |
replaced front ARB now. noise still there. LR looking at replac a bush in the lower steering column i believe 07 TDV8 + BAS map |
