Home > Faults & Fixes > Epb
damo
2009 Range Rover Sport TDV8 HSE Santorini Black
Epb
Has anyone encountered the dreaded electric parking brake failure. I managed to manually release it for now. Will be booking it in local garage. Is it a big job. How long to fix and estimate in terms of cost.
Post #407585 Mon Dec 30 2013 10:28pm
Bodsy
Site Sponsor
possibly just needs clean and adjust. Have a look at the brake bible in my sig. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #407597 Tue Dec 31 2013 1:26am
Disco_Mikey
It is had jammed on, and you had to pull the emergency release, there is a good chance the mechanism inside will be jammed.
As Bodsy says, try a strip and clean firstly, but if that does not cure it, you will probably need to try this: EPB Unjam + Relatch
Post #407600 Tue Dec 31 2013 7:24am
panda
Just had mine done
New electric actuator, new discs, new pads new shoes and new pad wear sensor.
parts came to about £600.00
Labour(friend of mine) wanted to charge me £ 120.00 but gave him £ 200.00 I still think that was cheap for amount of work.
I just thought if bits coming off replace with new.
Post #407605 Tue Dec 31 2013 10:19am
chrisebabes
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Mine was sorted by the RAC chap re setting it with his computer, worked ok ever since TDV8 2007 window tints, side steps.
Post #407858 Thu Jan 02 2014 7:28pm
