![]() | Home > Technical > EPB question |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
well the plot thickens.
Flat battery then ... |
guess so peachy, but WHY ? lol |
Could be numerous reasons but mine for some reason hates the cold weather -- I really don't run it as much as I should - it don't take long with all the electrics on - dark cold mornings - dark cold nights. Have you analysed your recent journeys it could be as simple as that. I've had everything checked twice over but after a good run it kicks over first time every time.I only do about 10 miles a day normally so there is my problem. |
Well that could be the problem, it has been really cold here the last few mornings, its not been used since xmas eve. think a good run out could be in order. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
Could be as simple as not having been run enough to charge the battery or could be early signs that the battery is sick or that the alternator is starting to fail. It's not unknown for TDV8s to need new alternators and yours is probably in the age range for it now. 2012 SDV6 - it's missing a couple of cylinders
