![]() | Home > General (L494) > Snow chains |
Disco Member Since: 15 Nov 2013 Location: Telford Posts: 178 ![]() ![]() |
You can specify the traction devises for the rear wheels for up to the 22 inch wheels. Do they fit really, not sure. |
Ilron Member Since: 23 Dec 2013 Location: Norway Posts: 2 ![]() |
Thanks, I have not tried the so called traction devices, but I guess they are worth looking in to as an alternative. |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Range rover recommend the Spike Spiders i believe and i think they should be put on the front axle. SVR 2018 in Santorini Black. |
SDV6RRS Member Since: 08 May 2013 Location: Hampshire Posts: 52 ![]() ![]() |
Not for the 2014MY. They say rear axle only.
There are many different types of chains that attach in a number of ways, a fair few don't hook round the back...but LR will recommend the set that takes into account clearance. Mike
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 ![]() ![]() |
Similar issue was told a NO on the fronts . spoke to someone i know who works on tech at the factory was told the only way was to fit 20" slightly narrower rims and tyres to run front snow devices / chains, otherwise rear only ! poor design IMO, Problem is with a 4WD is getting going is not the problem it's stopping them and getting round corners.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9151 ![]() ![]() ![]() |
How is it a poor design? The RRS was designed to accommodate up to 20 inch rims with a certain tyre size. If someone fits something larger than that then it's not LR's fault if stuff no longer fits. ![]() 2008 TDV8 - it was a labour of love and is much missed |
aburgh ! A standard RRS wheel and tyre will not take chains on its front end ? ! |
So the correct chains/devises on the rears and when needed snow socks on the front. |
Actually the 2014 sport comes with 22 as standard...I think that's the point. but then, same token as the last sport - 19" was the better size for off road etc, the 20" less good. THe land rover chain system (made by RUDD) is a good system (but a pain) because it only clamps on the front, using the bolts for the wheel and a plate - you then clip the chains to that. Rather than the cheap chains which you wrap the wheel in and damage the alloy
Snow Socks and chains do very different things - ignoring socks aren't legally a replacement for chains in Europe - there are conditions where the socks just wont work and you need chains. If you have chains on the rear I wouldn't bother with socks on the front... Mike 2014 Facelift Discovery |
Thought the 20" or 21" were the STD rims may be wrong and 22" are a pay for option.
http://www.snowchainshop.co.uk/autosock-snowsocks
Ah, yes, in that case it is a rather odd decision on LR's part. But then they seem to have made odd decisions in lots of areas in the last few years of product development. Maybe they've come to the conclusion that people in the UK who want to use chains are so rare that they didn't bother designing for them and just gave them the big shiny wheel choices they crave. A bit like the decision to drop the low range transfer box because people don't go off road. When most LR products live in towns and spend their lives on big shiny rims coated in summer rubber you can rather see their point... ![]() 2008 TDV8 - it was a labour of love and is much missed |
19" will not fit a 2013 on car , will not clear the brakes as far as i am aware,
