Home > In Car Electronics > question for bodsy
rrsfreak
Belgium 2005 Range Rover Sport TDV6 HSE Bonatti Grey
question for bodsy
hi bodsy,
i'm dave and live in belgium own a 2005 rrsport, is it possible to do the bleutooth module swap.
how swap works and costs please ?
Post #406792 Fri Dec 20 2013 10:06am
Bodsy
Site Sponsor
Yes, not a problem at all, I've currently got one on its way back from Australia, that came from one returned from Portugal and before that,returned from one in Oxford! Laughing Thumbs Up
Will drop you a message. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #406806 Fri Dec 20 2013 12:20pm
Bodsy
Site Sponsor
Just for other people reading, info on the module swap.
So I can post out an updated telephone module that stops you having to either re-connect the phone each time you get in the car AND updates the module so that you can choose your phone contacts on the radio screen.
This only works if you use 2121 as the connection code to the phone. It won't work if you use 0000 or 1234.
To change the module over, you go to the boot, on the right hand side is a small removable panel. Behind that, you can see a black module with two connectors, one large and black and the other much smaller wth orange Optical cables coming out of it.
There is a single t20 Torx screw that holds it in the middle.
Simply remove, swap out and post your module back to me
Then you will be able to automatically reconnect to the module without having to re-enter the code all the time. It also gives you the contacts list from your phone (up to 300 numbers).
It really is as simple as that!
Anyone else interested, please let me know. Thumbs Up
Ian Bodsys Brake Bible
See it HERE
Post #406809 Fri Dec 20 2013 12:33pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Are you about to unlock my FBH over Xmas I can come over to you if that helps
PLEASE Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down
Post #406828 Fri Dec 20 2013 6:27pm
Mitchmx
Hi bodsy
Sent you a pm about some work a few weeks ago. Did you receive it?
Post #406859 Sat Dec 21 2013 12:16am
Bodsy
Site Sponsor
Neil, that sounds like a plan bud. I could stop off on the way home Tuesday if it's just the unlocking and purging you want doing. Thumbs Up
Mitch, thought I'd replied and was waiting for you to advise? Will double check though Thumbs Up Bodsys Brake Bible
See it HERE
Post #406860 Sat Dec 21 2013 1:05am
ShooterNeil
Cool that's all I want for now then
updates later
Post #406868 Sat Dec 21 2013 8:56am
ShooterNeil
Just had a play and it has started Ian
3 tanks of vpower must of cleand out the small pump I pulled the fuse over and over and kept pressing the flame button she fired up happy days
Post #406888 Sat Dec 21 2013 12:15pm
Rossk3107
Scotland 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hey Bodsy, how much is it for the bluetooth module swap over? Thumbs Up
Post #407739 Wed Jan 01 2014 3:09pm
Rossk3107
Hey bodsy tried sending you a pm. Not happening since i dont have enough posts.lol
Post #407788 Wed Jan 01 2014 8:55pm
Bodsy
Site Sponsor
You do now. Thumbs Up
Will be sent out tomorrow. Thumbs Up Bodsys Brake Bible
See it HERE
Post #407790 Wed Jan 01 2014 9:55pm
Rossk3107
Thanks alot mate you truely are a legend! Thumbs Up
Post #407799 Wed Jan 01 2014 11:17pm
