Home > Maintenance & Modifications > Cam belt length
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Cam belt length
Hi im going to attemp the cambelt on my 06 2.7 v6d sport on saturday. I have just received the cambelt from an internet supplier and just want to confirm the over all length before I start.
The belt i have received is pretty small. 13" x 4" Does that seem right?
Also what size/diameter pins are req to lock off the cams, pump and crank?
Kind Regards
Post #406747 Thu Dec 19 2013 9:31pm
looneyfitter
pic [URL=]
[/URL]
Post #406749 Thu Dec 19 2013 9:41pm
Bodsy
Site Sponsor
That looks like the fuel pump belt, which should also have a new tensioner with it.
Cambelt is much bigger than that. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #406753 Thu Dec 19 2013 10:04pm
looneyfitter
I thought as much thanks mate
Post #406755 Thu Dec 19 2013 10:20pm
Disco_Mikey
That is the fuel pump belt. EU3 has 85 teeth, EU4 has 82 teeth Thumbs Up
Front belt is much much bigger. Cam locking pins, from memory are 5.9mm each. Crank locking tool is an odd shaped item, that cannot really be matched.
A set of locking tools can be had for £50 or so, from the usual places online, or from Advanced Factors Thumbs Up
Post #406760 Thu Dec 19 2013 10:40pm
Advanced Factors
Site Sponsor
How about a different internet supplier who knows these engines Whistle
http://www.advancedfactors.co.uk/1-click-h...-157-c.asp Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #406855 Fri Dec 20 2013 10:36pm
SRE
Spain
For such a vital part, I would only ever fit a genuine Land Rover Belt In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #406878 Sat Dec 21 2013 10:32am
Advanced Factors
Site Sponsor
No doubt made in the Land Rover belt factory Rolling with laughter Paul Redding
+44 (0)23 8052 2776
Post #406887 Sat Dec 21 2013 11:59am
Disco_Mikey
Land Rover buy them in from Dayco, which is available from Advanced Factors (^^^) for much less than Land Rover want Whistle
Post #406928 Sat Dec 21 2013 7:53pm
flack
Yep that would be a Dayco belt then Very Happy
Flack Thumbs Up
Post #406939 Sat Dec 21 2013 9:07pm
