![]() | Home > General > UPDATE! - £745 Quote from Land Rover - Extended Warrenty? |
| simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148
I checked with them that I'd be covered for that.
| 57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113
Just been quoted £1899 for 3 years or £750 for 1 year with everything covered. Will likely do the 1 year as would have to change car if job changed. No inspection needed and willing to do 4 x £175.50 quarterly interest free payments. |
That's not bad - is that with Warranty Direct?
52,500 so far & yes WD... trying to get wear & tear on day 1 & down to £700 so 4x £175, drop in the ocean compared to any work that needs doing. 2010 TDV8... |
Cool.
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186
Well a member on Disco3 forum had his EGR valves replaced under WD warranty. 2014 L405 SDV8 RR Autobiography |
So did i, also i had the EGR cooler replaced at the same time as this was found to be leaking when they removed the EGR valve, all covered by WD. |
| jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
These day 1 covers, do they include a "cooling period"?
1. As with most you have 14 days to cancel it.
Jack,
