Home > Technical > Remapping
Paul Holywood
May I ask, if the actuator rod is sticking through corrosion, is there a way to clean these successfully?
Post #406401 Tue Dec 17 2013 1:02am
Disco_Mikey
The only long term fix, is to fit the modified actuator rod, and stainless bolt
However, it is a right PITA to do, so normally, the rod is drowned in penetrating oil, and worked up and down until free. Much easier to do, and as good as free to repair Thumbs Up
Post #406404 Tue Dec 17 2013 7:53am
Paul Holywood
many thanks DM Wink
Post #406411 Tue Dec 17 2013 9:06am
