![]() | Home > General > horn sounds when locking |
| cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882
when i lock my car the horn makes a beep sound |
Have you had the bonnet open recently? |
cheers for the fast replys , i fitted a new grill today so had bonnet up but it does apear to be shut, i will check tomorrow as its been fine for over a year lol |
You may of disturbed the wires leading to the bonnet catch sensor for the alarm then, check there first. |
| V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145
Try this...
| BlackRRSport Member Since: 15 Dec 2012 Location: United Kingdom Posts: 3
Any advice for the same problem on the Wife's 08 RRS?
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Could be any of the doors, tailgate or bonnet not 100% shut In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
It's definitely the bonnet |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Just a guess but is the release cable or mechanism seized? Does the hood release lever spring back into the detente position when you release it or just stay in the same place? 2008 MY Java Black TDV8 HSE
Good shout, I'll check in the morning. |
| stevew Member Since: 16 Oct 2013 Location: solihull Posts: 75
I had this on my old tdv8 , sensor needed replacing on the bonnet, I was told its a common fault |
| simonsti Member Since: 29 Apr 2006 Location: staffs Posts: 193
I have to really slam mine to shut it properly. 2014 Nara Bronze SDV6
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950
Happened to my old TDV6 after it came back from service at LR. Turns out it ws the bonnet latches seized, even though part of the service was greasing and checking operation of latches |
| All times are GMT |
