![]() | Home > General > how good is the cruise control |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
It's not me driving too close, it's when a car pull back infront of me that cruise slows down till it has enough space, then someone else jumps in too.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9135 ![]() ![]() ![]() |
Works for me - outside lane at humpty miles per hour! |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
I think it's marvellous, I love mine |
Maybe it's just me who doesn't know how it works.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
The sensor gets covered by snow this time of year, which can be annoying.
That just means it's noticed something in range of its sensor. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
^^^^ So that doesn't mean it's lifted off the throttle then?
On mine the icon lights up about 100yds away from another vehicle in the same lane. If I've got it set to one of the longer distance settings it'll back off the throttle if there is a reasonable closing speed. Braking rarely occurs. If I've got it set to a close following distance then the brake activation is often quite firm. I usually set it to long range initially and the modify the range to suit conditions. I've found that quite fine control can be achieved that way even with both feet off the pedals. 2012 SDV6 - it's missing a couple of cylinders
I assumed when the icon come on (I'd say about the same distance as you have stated) it had started to adapt its speed, hence why when I've go it on the close setting the icon was still lighting up at the same distance.
Read the manual? |
I was going to put id get the wife to read the manual, then I was expecting the reply "why can't you read?"
dannyboy Member Since: 10 Nov 2013 Location: oxford Posts: 32 ![]() ![]() |
funny thing manuals i didnt read how to put the cd in on the manual.... but the first thing i did when i got home was google the issue and got a link to the manual .....that i then read |
I didn't like it when I had it, not for me.
really i thought the other lanes were for going really fast |
