![]() | Home > Technical > found my air suspension leak.... need to know what to do now |
I would just undo it and see if the pipe is split if not clean it up and try it again to see if it leaks..I have used ptfe tape on these joints to seal them..
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
thanks, i was going to suggest ptfe tape but did'nt want to get shot down lol
Good luck with air drier as most I have done are to far gone and you end up with a new compressor..
hmm well if thats the case, i wont bother as compressor works fine just it wont go into access mode |
does anyone know where i can get an olive (presuming the fitting onto the airbag has an olive inside to hold the plastic pipe) |
is the pipe work 4mm or 6mm to the rear air bags? |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
is there an error saying why it won't go into access mode ? ie. obstruction? |
what on the dash? ive not had it plugged in, i'll have to check but it says raising to extended mode deffinately |
yes, an error usually displays on the dash |
hi b3eee
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
which means your compressor is goosed |
Plenty of people have changed compressor for this and its still caried on. Thing is it goes up and down in seconds on all other modes. If compressor needs replacing ill just leave it. I can live without access to gain £500 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Is this vehicle second hand? If so, someone might have played with the EAS settings, e.g. with an IIDTool, so that access height sits it on its bump stops before it gets fully down (as far as it considers fully down). 2012 SDV6 - it's missing a couple of cylinders
Yes it is secondhand. |
