![]() | Home > Technical > RRS TDV8 multiple fault messages |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
I imagine it just the battery struggling with a cold start. Hopefully after a long run or zap of a battery charger you'll be fine. Happened to me recently and my battery terminals weren't on tightly enough- so worth checking. |
MartyRRS Member Since: 04 Dec 2013 Location: Adelaide Hills South Australia Posts: 25 ![]() ![]() ![]() |
Thanks for the reply. I have done about 300km this week so the batt should've been fine. Just checked both batteries with multi meter at the terminals - the main was 11.1 the secondary 11.0 - and yet the car still starts! The main is the original from 2008 and the secondary is 2011. Sitting in shed on the C-tek to see what happens. I think 2 new batts may be on the horizon..... p.s. the terminals were tight and clean. Regards, Marty
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
All the symptoms of a blocked fuel filter, or brake light issue, either bulbs or a switch |
thanks - my list is growing of items to check, the beauty of these forums, being able to access such a large pool of knowledge and experience, thanks again. Regards, Marty
Apologies for saying the battery may be struggling with the cold start. I have just noticed where you live and guess it's not too cold there! Certainly covers some miles this forum!!
no worries, it was a bit cold for us - about 15 deg C....... Regards, Marty
15 degrees isnt far off our summer |
its warming up a bit here - sunday will be a mild 28....... by Xmas probably around mid to high thirties |
