Home > In Car Electronics > Sat Nav reboots - Seems to be when it is cold. |
Sounds like a power issue to me
Mon Oct 14 2013 10:50pm |
Steven D Member Since: 08 Oct 2013 Location: Lancashire Posts: 19 |
Thanks for the reply.
Tue Oct 15 2013 8:04pm |
Rather than thinking does the sat nav need more power when cold - its more, does the car have enough power to support the car.
Tue Oct 15 2013 11:17pm |
Dhups Member Since: 15 Sep 2013 Location: Essex Posts: 183 |
I get this issue too and only when its a cold morning.
Wed Oct 16 2013 12:38pm |
Hi Mike,
Wed Oct 16 2013 5:57pm |
Yes ultimately it could be anything - but given the battery and alternator issues are usually minor faults and cause weird major issues - i would start there, rather than wiring that hasnt ever moved. Although i can imagine things like earth connections could all come into play.
Wed Oct 16 2013 11:17pm |
Cheers again for your reply Mike.
Thu Oct 17 2013 4:08pm |
Steve,
Thu Oct 17 2013 6:23pm |
Cheers Paddi for the advice.
Thu Oct 17 2013 6:51pm |
finbarfinnegan Member Since: 26 Aug 2011 Location: Banbridge Posts: 19 |
Hi Steve.
Tue Oct 22 2013 10:18pm |
Hi Steve,
Wed Oct 23 2013 5:58pm |
It all actually started after the alternator burn out. It didn't happen before that.
Wed Oct 23 2013 8:41pm |
Hi Tim (apologies for writing Steve last time!!! )
Wed Oct 23 2013 8:51pm |
planko Member Since: 23 Nov 2013 Location: Perthshire Posts: 1 |
Hi. I had the same issue after alternator burnt out. Power would pulse as soon as i turned the ignition key then go away after a couple of revs.
Thu Dec 05 2013 8:21am |
