![]() | Home > Technical > How do I reset extended mode please |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
Compressor goosed
PatGapInnov Member Since: 30 Jul 2012 Location: Montreal Posts: 42 ![]() ![]() |
What`s happening is that one of your corner is reaching the bump stops and the vehicle can`t lower to the desired target. This triggers the extended mode since the suspension ECU thniks the vehicle is grounded. Was your suspension lowered in any way? |
highfellzippy Member Since: 06 Dec 2009 Location: yorkshire Posts: 256 ![]() ![]() |
Think a sensor was playing up near side rear all over the place |
That could explain it. Any faults code stored in the EAS ECU? If a sensor is defective, it will eventually show up. |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
does the message say 'vehicle will lower once obstruction removed' ? - sounds like height sensor |
