![]() | Home > Faults & Fixes > Gearbox Fault |
| Kenzi Member Since: 24 Jun 2013 Location: Perth Posts: 101
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
Try a hard reset (battery disconnect). |
Just out of interest, what would this do? |
Thanks for clearing that up. The linkage is fine as this has been checked and the gears move freely.
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
You need to Contact Liam on the forum and explain your situation and that the car is just out of warranty and see if he can help in any way it should not fail at this mileage.
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
Multiplate clutch E is used in gears 4, 5 and 6 so that would seem to match with the speeds it shows the error.
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
That DTC doesn't sound good. If LR can be persuaded that you have a case and help out that's good.
| drakkarnoir Member Since: 29 Nov 2013 Location: saarbrücken Posts: 1
Dear Kenzi,
I have just had the gearbox replaced as it was the only option.
| jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15
HI
Hi and welcome,
Hi paddi
Just a thought, the judder isn't the EPB disengaging is it? 2012 SDV6 - it's missing a couple of cylinders
