Home > In Car Electronics > Adding Freeview/Rear View Cam Required
Page 4 of 4 <1234
PEACHY
TLL - mine kicks in when on Sat nav screen - I never ever have a problem - I put it on Sat nav screen - start car in the mornings - don't press any buttons - put car in reverse & screen defaults to camera. This stays like this for weeks at a time it's the same screen for my freeview & Blackvue - I just toggle through the inputs using fixed button or remote Whistle .
If you want I will send you a video of the whole process Thumbs Up 16MY Estoril Blue SVR.............
Post #404227 Fri Nov 29 2013 5:33pm
tanloverluke
is it only when it's on satnav screen Peachy, what about when you're in the main screen ? i'm hardly ever in satnav screen and dont want to have to switch to it just to have to get the reverse camera working. call me lazy !
if it's only when you're in the satnav screen, then the next question is why harry can get it in any screen and you can't Question Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #404232 Fri Nov 29 2013 6:01pm
Bodsy
Site Sponsor
The gvif unit plugs into the satnav DVD player and interrupts the signal to the screen, therefore, it needs to be on the satnav screen. The warning message screen is ok, it doesn't need to have the map on specifically. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #404233 Fri Nov 29 2013 6:26pm
tanloverluke
bodsy, why then is awd man getting the reverse camera coming on regardless of what screen he's on ? it's due either to 1) it being wired incorrectly, or 2) he's dillusional Laughing Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #404236 Fri Nov 29 2013 6:39pm
Bodsy
Site Sponsor
Errrrr without offending, I'd have to pick number 2... Whistle Bodsys Brake Bible
See it HERE
Post #404237 Fri Nov 29 2013 6:41pm
tanloverluke
just pm'd him...let's get this put to bed once and for all.
Harry, what about you...only on the satnav screen or does it appear regardless of what screen you're in ?
cheers / Luke Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #404240 Fri Nov 29 2013 6:46pm
PEACHY
TLL - Harry has the same set up as me - helped by Bodsy I believe Thumbs Up it sounds worse than it is - what do you use your other 2 screens for ? Settings & 4x4 mode ??? Do you live in a field & need to change the settings on your music every 2 mis Rolling with laughter - I will video it tomoz & send it to your e-mail Thumbs Up 16MY Estoril Blue SVR.............
Post #404241 Fri Nov 29 2013 6:49pm
tanloverluke
Peachy, i live in dorset which is one big muddy field ! the problem i suppose is when im faced with a restriction, in this case having to be on satnav screen, my brain goes all funny and negative. i want things to be easy and smooth (just like my hoes Mr. Green ).
that's kind of you to make a video for me! cheers ! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #404244 Fri Nov 29 2013 7:17pm
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
TLL sorry about the late reply been away for a while.
Reverse camera comes on every time the vehicle is put in reverse regardless of what screen your in, once you put the vehicle back into drive it returns to the screen it was initially on.
Post #408870 Thu Jan 09 2014 7:44pm
tanloverluke
Thanks for that Harry.
Do you also have the gvif unit? who installed it for you?
cheers! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #408881 Thu Jan 09 2014 8:45pm
Harry HST
TLL the topic details everything that was installed.
Myself and a friend installed all
Post #408921 Fri Jan 10 2014 8:38am
flydive
Not if you are on info 4x4 screen '08 RRS TDV8
Post #408955 Fri Jan 10 2014 11:57am
Page 4 of 4 <1234
