![]() | Home > Technical > Drivers Side Xenon |
| Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278
You should be able to adjust the height of the beam. There are 2 adjusters on top of each headlamp, one for horizontal and one for vertical adjustment (can't remember which is which, I'm afraid).
| 57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113
Appreciate the help mate! Now managed to adjust it much lower to match the passenger side and on a flat road it's now not pointing off to infinity, blinding other poor soles on the road! Thanks a lot! Just as a note for others, adjustment near the grille end of the headlight appears to adjust height, good job as I could barely reach the other hex & you're right 6mm. 2010 TDV8... |
| All times are GMT |
