![]() | Home > Technical > What Diesel? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4462 ![]() ![]() ![]() |
I fill up with Tesco finest diesel, purely down to convenience. A bit lumpy on very cold starts, but otherwise runs fine, and still returns 30+ mpg on a run |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Shell V power for me,a bit more expensive but I get 5mpg more with it ,the car runs better.Pays for itself and some |
Shell Nitro+ for my motor, Ive been putting it in from new, and Ive never put anything else in. Not sure if i get anymore mpg, but i don't really care. Currently getting 27 mpg on a 18 mile daily round trip, all B roads. |
Generally use supermarket fuel but every so often (5 or 6 fills) I give it a treat of the BP or Shell expensive stuff! |
BP ultra + 2T
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
I used to use normal Esso diesel but for the last 12 months or so I've been using either Esso Supreme or BP Ultimate (I think those are the names). I doubt it gives any more performance really but I hope that the better cleaning additives will be better for the engine... |
oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148 ![]() ![]() ![]() |
If you google about cheap supermarket fuel you will find quite a lot about the lack of lubricants in cheaper fuel.
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
doing main in town driving using Tesco diesel i used to get 290 miles per tanks, when Shell opened a branch i swapped to using their Fuel Save Diesel and the occasional once or twice a month tank of Nitro + I now get 350 miles per tank and the engine doesn't rattle as much |
If your car is fitted with a DPF it is not a god idea, in fact its a pretty bad idea, to add 2 Stroke. |
The 2so debate will of course never end but I thought one of the proven benefits of adding 2so was less frequent cleaning of the DPF http://www.freel2.com/forum/topic878.html 2008 MY Java Black TDV8 HSE
^^^^ True its a subject around which there are a load of opinions.
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Thanks for posting that link Paddi, there is some really interesting arguments put forward by the German chap there. I have a couple of gallons of two stroke oil in the garage sitting about as it happens......
Dhups Member Since: 15 Sep 2013 Location: Essex Posts: 183 ![]() ![]() ![]() |
I've used Shell V power nitro since ive had the car.
I think 'Yamaha fan' is in fact.... A GIRL! But I'm definitely not getting drawn into the 2so debate as there are more than enough posts on numerous websites if anyone wants to read up on the subject. The case for using premium fuels though is proven IMHO so would definitely support it. My TDV8 certainly likes Shell V power nitro stuff and runs more quietly. 2008 MY Java Black TDV8 HSE ![]() |
