| RRSPORT.CO.UK | ||
|  | Home > General > 2012 Timed Climate???? |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  |
 Yes I can.. Flack   | ||
|  Fri Nov 15 2013 6:43pm |
| rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879    | Booked in for Wednesday, cheers MSE  | ||
|  Sat Nov 16 2013 10:12am |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | no problem Mike
|  Sat Nov 16 2013 10:52am |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | biffo
|  Sat Nov 16 2013 6:21pm |
| peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585    | Flack... I'm just going to pm you for further info. Maybe you can combine me and Biffo at the same time. I work from home so pretty flexible during the week, but mornings are good. | ||
|  Sat Nov 16 2013 8:20pm |
| rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879    | When you have the remote option fitted, can you also use the timer function on the screen when you want to or is it one or the other ? MY16 AUTOBIOGRAPHY Indus silver with some toys
|  Sat Nov 16 2013 8:37pm |
| peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585    | Just a thought...what are the warranty implications with having this fitted outside of the LR network? | ||
|  Sat Nov 16 2013 9:15pm |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | @rigsby
|  Sat Nov 16 2013 9:59pm |
| peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585    | Ok, many thanks... | ||
|  Sat Nov 16 2013 10:15pm |
| rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879    | Thanks Flack MY16 AUTOBIOGRAPHY Indus silver with some toys
|  Sat Nov 16 2013 10:18pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | Apparently the 2014 firmware is different - so you will need to check the earlier equipment will be able to enable it. That said, this is actually the same as its been in the past, certainly for the 2013, it was different to the 2012 and the 2011 - I know because i had this when I went to do it and had to update the to the latest interface (but then autologic is the best system going and gets the updates out very quickly).
|  Sat Nov 16 2013 10:19pm |
| rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879    | Found this information on another thread from a couple years ago, it relates to 2010 my on. Can somebody confirm if these are the parts required for a 2012 SDV6 , thanks
|  Mon Nov 18 2013 3:32pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | Youll need to ask someone who has the latest parts cat or dan at duckworths Mike
|  Mon Nov 18 2013 5:52pm |
| Macdaddy Member Since: 12 May 2012 Location: NW Posts: 101  | We've finally after 18 months of having the vouchers got booked into the Peckforton LR experience on the 28th of Nov,  Looking forward to giving the RRS a go in the mud.
|  Thu Nov 21 2013 7:05am |
| Posting Rules
