![]() | Home > General (L494) > InControl |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9115 ![]() ![]() ![]() |
Who needs a wifi hotspot in a car? What's the benefit over the usual method of tethering to your phone to provide a data link? Presumably you just end up with two bills - one for the phone and one for a sim in the car wifi system.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1909 ![]() ![]() |
Exactly!! 2023 P440e SE Dynamic on order -cancelled
Re wifi hotspot, agree with RRSTDV8! ON THE WAY: BMW F21 M140i
leondrums Member Since: 02 Aug 2011 Location: Norwich Posts: 171 ![]() ![]() ![]() |
I have no idea what you mean by tethering? I wanted to google a saddle rise opening times last Saturday and had no 3G as I was in the sticks so in events like that some kind of connection would be good... 2017 MY - Dynamic, same again!
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
If you was in the sticks with InControl how would that help? No signal is no signal, it's not going to build a mast and connect to your service provider |
That's what I am saying - is that I do not understand!
As Nick says, if your phone doesn't work then the chances are that the car's system won't work either. Now, they might have designed in a clever aerial to improve connectivity in low signal areas, if not I don't see why it's a benefit.
The WiFi in the car will let you connect things in the car - but the car needs to communicate with the outside world which will usually be via the cellular network for which some-one pays. That's unless you have satellite phone etc which is mega bucks.
In the car if the car is receiving a signal
Cool - got it! So personally for me there is no point for InControl as a cost option.
In that case |
There is some info on this system publically available - im sure there was even a topic on here when it first came up.
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Seems only to make sense if it enables a better internet connection than from a phone or tablet directly by using a better aerial and more powerful transmitter. That said, the technology will be frozen in time, so by the time we are on 7G networks, this will appear like a dinosaur, a bit like 10 year old fitted sat-navs do now.
I guess the wifi hotspot would allow several passengers to make use of a single 4G connection to stream content but that in itself is going to be very pricey - the mobile companies are going to love this sort of technology in cars because they're going to be making a lot more money from data charges.
