![]() | Home > Maintenance & Modifications > TDV8 Gearbox Cooling Radiator and feed pipes |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
in front of front right wheel (under the bumper)
I hate to sound like a smart arse but err... that's wrong actually. The extra little radiator in front of the front right wheel is in fact an auxiliary radiator fitted to the TDV8 and the S/C, presumably to cope with the extra heat generated by the larger engines. The TDV8 transmission cooler is situated just behind the bottom of the main radiator pack in the middle. You can see it in the schematic in my gallery here: http://www.rrsport.co.uk/gallery/albums/us...layout.pdf 2008 MY Java Black TDV8 HSE ![]() |
TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96 ![]() ![]() ![]() |
Perfect. Tx! Paddi |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
Don't worry adigorn, you're not the first one to think that the little radiator was an oil cooler |
