Home > In Car Electronics > No satnav and no volume. |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
All the modules are linked with a fiber optic most cable, that are daisy chained together, if one module is not working then it breaks the chain and thats why your sat nav is not booting up.
Tue Nov 12 2013 8:52am |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Thanks for the reply. There is still a red light coming from the MOST cable. Although damage to it or the main harness due to my fat fingers seems the mist likely, pretty sure it's not the new module as the old one doesn't work now either, and it was fine before I started messing about. What do you mean by creating a loop?
Tue Nov 12 2013 9:15am |
The loop is a piece of most cable that just plugs on to the most cable that goes in to the module, its just an in -out for light to travel to the next module, so bypassing the one with the fault.
Tue Nov 12 2013 9:27am |
No i haven't earthed the new module- didn't know I had to- I was led to believe it was a straight swop over?
Tue Nov 12 2013 10:25am |
It's the BT module Mick so no earth bolt.
Tue Nov 12 2013 10:23pm |
Thanks Boddsy; the white bit has completely broken off so I'm pretty sure it's correctly seated.
Tue Nov 12 2013 11:34pm |
Just to tie this one off- went to the garage today- when I'd fitted my new Bluetooth module is put the main harness connector back in the wrong way round. Dealer corrected it- re- synced all the modules and all is well- with all the functionality of the new module (thanks Boddsy) so all is well, all for the princely cost of £57!
Mon Nov 18 2013 7:30pm |
Well I'm glad that it's all sorted and didn't need a new MOST cable Run!!!
Mon Nov 18 2013 8:55pm |
