Home > General > Fuel Burning Heater
Page 8 of 12 <123 ... 789 101112>
rigsby
Hi Muddy, mine is going in Wed to be activated on the screen but now considering getting the rest of the bits needed and going the whole hog and using the remote. Not sure if the parts required have changed or if the items above are still correct, don't want to buy the wrong bits Big Cry MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #402666 Mon Nov 18 2013 10:53am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi Rigsby, What is the cost to Actvate the on screen timer for FBH? 10 MY 3.0 HSE are you having it done at Main Stealer or an Indi Regards Harry itisme
Post #402699 Mon Nov 18 2013 2:39pm
rigsby
Hi Harry,
stealer said it couldn't be done unless I parted with £plenty Rolling with laughter
Indy doing it for £50 Bow down MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #402700 Mon Nov 18 2013 3:02pm
harrygh60
Hi Rigsby, That sounds more up my street. I have two Indies near me, and i have someone who does Electronic diognostic work for many main stealers, he has thousands of pounds in software that mybe cover this operation.If not who is your Indy. I am down at Hayling Island in January. How long does it take
Post #402717 Mon Nov 18 2013 4:36pm
rigsby
Hi Harry,
Unfortunately it is not down here but up in Warwickshire. MSE kindly gave me the details and I'm sure he won't mind me
giving you the contact if you are up that way. Takes about 20-30 minutes I believe.
Just PM me or MSE if you need the number (hope that's ok MSE) MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #402719 Mon Nov 18 2013 4:43pm
mse
Quote:
Anyone know if you can do it to the Supercharge?
Superchargers don't have the park heat unit as standard...did you have it fitted? Mike
2014 Facelift Discovery
Post #402733 Mon Nov 18 2013 6:52pm
harrygh60
Park Heaters
Hi Mike My 10MY 3.0 TDV6 has the FBH already fitted. But was not enabled to be used as a Park Heater. There isn't any timer on the Sat Nav screen. I had the 2008 2.7TDV6 with FBH and was told that it could not be enabled without spending loads of dosh. But was told the 2010./ on 3.0 TDV6 could be activated,if the FBH was already fitted.
Harry itisme
Post #402783 Tue Nov 19 2013 9:31am
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
If it not fitted as standard on the supercharge than no. Thought it might be like the rest. All you had to do was activate it. Ah well. Censored MY11 Autobiography supercharged. Santorini Black. Monaco interior. Rear screens. Privacy.
Gone MY08 Supercharged HST. Java black. Ivory premium interior. Rear screens. Privacy. Missed a lot.
Gone MY04 Discovery V8 Petrol ES Premium. Awesome.
Post #402784 Tue Nov 19 2013 9:56am
harrygh60
FBH Activation
Hi Sweetafton, Seems as though MSE has different veiws on this subject. In 2011 he posted that if you had the hardware already fiitted. Then it was a software issue. And just needed the right software to be downloaded to activate the excisting hardware.Landrover would have activated this facility when ordering from new at a high price. Its like the old days when all models of a particular car shared the same wiring loom. And the higher spec model had the extras fitted and plugged in. It was cheaper to have one wiring loom than to have several different ones MSE makes sense if its there it just needs the no how to get it to work
Harry itisme
Post #402786 Tue Nov 19 2013 10:30am
Harry, the S/C didn't have the FBH as standard - it was an option that had to be specified at build. No doubt it's possible to retro-fit one but as it'll likely include all of the fuel piping etc. back to the tank, it's probably not a cheap job.
All of the diesels in the UK have the FBH as standard. 2012 SDV6 - it's missing a couple of cylinders
Post #402787 Tue Nov 19 2013 10:47am
harrygh60
FBH
Hi RRSTDV8, My mind is focused on HSE Diesel. So that is where i am coming from. i have the FBH already fitted but require the software downloaded to operate and set the timer on sat nav screen.Harry itisme
Post #402795 Tue Nov 19 2013 1:52pm
mse
Risgby - no problem mate Thumbs Up
Harry
Sorry no idea what your going on about - my views are really clear - only one view, sorry you probably need to re-read the question.
The FBH is only fitted to Diesels as standard to aid the warm up, this can be enabled with either timed climate (the sat nav screen) or remote park (the remote control option). To have the remote control you also need the remote, sender unit and aerial
Now there are at least 4MY differences which require the diagnostic equipment to be set up to interface with. Pre 2010, 2010-11, 2012 and 2013 (now maybe added in 2014)
Supercharged or S/C...or SC (what the person above actually asked me about), didn't have the actual unit that does the work, fitted as standard unless you actually specified it. If you spec'd it, you will have the functionality as standard because that's what you ordered Whistle
Really simple - but I hope that's helped you
Its funny the FBH questions almost as soon as it gets cold every year Rolling with laughter Exclamation Exclamation Rolling with laughter Mike
Post #402797 Tue Nov 19 2013 2:07pm
harrygh60
FBH
MSE, maybe i didn't make myself clear. But what you have just said is what i was trying to say. I have the FBH already fitted I now need it activated to work on a timer set on the sat nav screen. Which facilty i haven't got. I have now found an Indy to do this for me in London, Booked in for next Tuesday. Sorry for any Confusion or upset i have caused Bow down
Harry
Also thanks to Rigsby for info Haggled and got mine done for same price itisme
Post #402819 Tue Nov 19 2013 5:28pm
Htailor23
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
FBH
I've just bought a RRS from LPR, and trying to find out how much the FPH costs to have activated. Also does it come with a Remote or is this extra.
I've been told the FBH is already installed and just needs activating, as the option is not on the ICE screen.
Post #407738 Wed Jan 01 2014 3:09pm
rigsby
The timed climate (on screen) will need activating and if you want the remote then it's an aerial, a receiver and the remote fob. Have a search under "2012 timed climate" for more details MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #407748 Wed Jan 01 2014 4:27pm
