| RRSPORT.CO.UK | ||
|  | Home > Technical > 05 Range Rover Sport Tdv6 SE starts then stalls |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Could it be some of the glowplugs faulty? Would a diagnostic check with a suitable fault code reader help to pin point the problem? According to other posts on the forum getting the glowplugs out is a real 'beeatch' to do so if it proves necessary make sure you take it to someone with lots of experience with this job on this engine. 2008 MY Java Black TDV8 HSE
|  Sun Nov 17 2013 6:04pm |
| monkers2003 Member Since: 04 Mar 2013 Location: Chester Posts: 28  | I'm not sure. Ive heard MAF sensor and ecu temp sensor issues could be causing a problem.
|  Sun Nov 17 2013 6:10pm |
|  Sun Nov 17 2013 7:10pm |
| monkers2003 Member Since: 04 Mar 2013 Location: Chester Posts: 28  | Yea will do. Well it sometimes runs a little rough at idle. And I do remember a couple of months ago a diagnostics check showed cylinder 5 misfiring. | ||
|  Sun Nov 17 2013 7:21pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Glow plugs or injectors   | ||
|  Sun Nov 17 2013 8:08pm |
| adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110      |
 or HP Pump   | ||
|  Sun Nov 17 2013 8:34pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Not convinced, but these cars are strange beasts. Could be a brake light bulb   | ||
|  Mon Nov 18 2013 6:50am |
 wasn't making it up speaking from experience   | ||
|  Mon Nov 18 2013 9:00pm |
| monkers2003 Member Since: 04 Mar 2013 Location: Chester Posts: 28  | Just an update, the cars going to land rover today and they are keeping over night to see how it starts in the morning. It took a while to start this morning as it was around +1 degrees.
|  Tue Nov 19 2013 9:16am |
| Saeedasghar Member Since: 10 Dec 2012 Location: Worcester Posts: 104    | Get them to check the O rings on the fuel pipes mate some times they wear down and start taking air in. | ||
|  Tue Nov 19 2013 1:11pm |
| Big Dave Member Since: 16 Aug 2013 Location: London/Essex Posts: 42      | I'll be interested in what they say on this, I had an identical issue with my SC and found it to be a low battery. Now I put it on the C-tek once in a while and I've not had a problem since. 2011 Evoque Si4 Dynamic plus lux
|  Wed Nov 20 2013 3:09pm |
| Claus1949 Member Since: 14 Dec 2013 Location: Marhsfield Posts: 4      | Hi
|  Sat Dec 14 2013 6:34pm |
| monkers2003 Member Since: 04 Mar 2013 Location: Chester Posts: 28  | Just an update on this.
|  Tue Dec 17 2013 4:16pm |
| Claus1949 Member Since: 14 Dec 2013 Location: Marhsfield Posts: 4      | thanks for that, just wondering what's causing this problem. Mine started first time today, but stalled yesterday.
|  Tue Dec 17 2013 4:38pm |
| Posting Rules
