Home > General > Lowering electronically
rigsby
Can someone give me any info regarding the amount of adjustment on the air suspension (2012 model) using one of the lowering modules like the GAP unit. Is it right that if you go lower by more than 15mm or something then the suspension throws a wobbly.
Anyone with first had experience, thanks MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #401983 Wed Nov 13 2013 9:58pm
rigsby
Found info on another thread, but thanks anyway for looking Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #401990 Wed Nov 13 2013 10:43pm
garrycol
Australia
I have a LLAMs system fitted and drive around with the cars system set to on road height and LLAMs set -20mm. Drives fine no issues at all.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #402012 Thu Nov 14 2013 2:56am
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
At -20, can you engage access height without the car bouncing back to extended setting?
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #402014 Thu Nov 14 2013 3:19am
garrycol
Australia
Hi Gordon,
I rarely have a need to go to Access height but most of the time it will go down without issue. Sometimes I do get the raising to extended message BUT the car does not actually rise and the extended message goes away straight away and the access height symbol on the message centre stays.
My thoughts are that when parked on level ground there are no issues but if not onlevel ground the sensors are outside a little and start the raising process but then everything balances and it remains at access.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #402016 Thu Nov 14 2013 3:38am
flydive
Same here.
I used to have the extended message all the time with -20 and access, now it seems like I'm not getting it anymore(do not use often the combination.)
Probably a bit of off roading solved the problem Wink '08 RRS TDV8
Post #402022 Thu Nov 14 2013 9:42am
Usually the extended suspension message only comes in if you lower more than 25mm (on flat ground)
(The car is basically hitting the bump stops and thinking it's hit the ground) RRS gone
Post #402070 Thu Nov 14 2013 3:04pm
RRS Daz
That's not as good as the full fat then.
I found that the full fat could be plugged in (forget what the machine was called) the values changed and no problems.
We changed the value to the lowest possible, drive it so it adjusted and when I got back it was very very low. Drove with no faults etc. I think the sports suspension is quite hard to start anyway.
Can the sport be plugged in and the values changed or do you have to buy a unit?
Post #402080 Thu Nov 14 2013 3:56pm
Only via a unit Darren Thumbs Up
It only errors if you select "access mode".. In normal you can lower it to -50mm which would be very bumpy but would work fine... Laughing RRS gone
Post #402088 Thu Nov 14 2013 4:24pm
RRS Daz
Hmmm not sure I'd pay for a unit to do it then if then when I park and put it into access mode it throws a fault code up.
Post #402121 Thu Nov 14 2013 9:00pm
rigsby
Wouldn't want faults of any sort, never mind paying for them Shocked MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #402137 Thu Nov 14 2013 9:53pm
flydive
No fault codes here '08 RRS TDV8
Post #402171 Fri Nov 15 2013 12:08am
garrycol
Australia
The messages are not faults - they are simply messages telling you what is going on. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #402173 Fri Nov 15 2013 12:57am
rigsby
Ok! No faults Thumbs Up , that's good. So those that have a lowering unit, what amount can you lower the suspension and still have an good ride quality ? MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #402175 Fri Nov 15 2013 2:15am
garrycol
Australia
As I indicated above I run mine at -20mm (is just a flick of a switch to change from onroad height to -20mm, or +30mm or +50mm) and the ride is the same as at onroad height, no change in tyre wear, no need to do a wheel alignment.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #402176 Fri Nov 15 2013 2:21am
