| RRSPORT.CO.UK | ||
|  | Home > Technical > lower tailgate lock |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Hi, We are all very civilised on this forum   | ||
|  Tue Nov 12 2013 5:27pm |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193      | Hi and thanks for the response.
|  Tue Nov 12 2013 8:30pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Ah... Was thinking you had same problem as first time. I agree you wouldn't expect the switch to be faulty if it is opening the upper tailgate. Sounds like a wiring issue. Did you find this thread with the wiring diagram for the tailgate?
|  Wed Nov 13 2013 10:59am |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193      | Great thanks for that, i will sit and go through the wiring diagram tonight, and see if i can get to my dads car tomorrow. I have already removed the lower trim panel and left it off just in case it fails altogether. I will let you know how i get on.
|  Wed Nov 13 2013 2:05pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | You might find this explanation of the codes used in the wiring diagrams helpful:
|  Wed Nov 13 2013 2:47pm |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193      | Update on the tailgate lock / button not working. I had arranged to have another look on saturday and to check the wiring through the tailgate hinge. But on Friday afternoon as my dad pulled into the petrol station he said that there was a fast repeated clicking from the boot, and something flashed up on the dash, but it was that fast he only caught the word boot. After this the boot lock and button has worked flawlessly. I know there is a lroblem there and its likely to happen again, but as at the moment its working it makes it impossible to trace a fault. I have tried everything to make it breakdown again but it just doesnt want to break.
|  Mon Nov 18 2013 5:25pm |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193      | Just to close this thread now, i have traced the fault stopping the lower tailgate from opening.
|  Mon Jan 20 2014 4:47pm |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193      | Probably a silly question, the lock is on order but when i fit it do i have to sync it to the car, or is it plug and play.
|  Tue Jan 21 2014 4:30pm |
| Posting Rules
