![]() | Home > General > Windscreen wipers |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9092 ![]() ![]() ![]() |
If the vehicle started ok then it's not likely to the battery. Most likely is that the motor's fried and/or something has seized in the mechanism that links the motor to the wiper arms. Check the relevant fuse to see if its blown. 2012 SDV6 - it's missing a couple of cylinders
Anders-01 Member Since: 25 Jul 2012 Location: London Posts: 13 ![]() ![]() ![]() |
Hi , thanks for reply , have checked all fuses etc . Just seems a bit strange that the last time I used car they were fine . The wipers do start to move but stop after about 3 inches have assisted them across the screen and back to there resting place . ( on a wet screen of course ). |
No ones messed with the bolts that connect them have they?
Well as the temperature outside was below zero in the London area last night could it be that the wiper blades were frozen to the screen?
Thanks guys for replays , it was cold but didn't go out to car until the sun was up so not frozen to screen . Will take wiper arms off in the morning and see if the splines are moving freely ( good idea ) hope fully I will just need wiper arms and not a new motor , have any of you guys change a motor before ? Looks a pig to get to . Anyway will update tomorrow . Have a good evening . I said I wouldnt buy another one ! |
Anders,
Have just found another post marked wipers gone mad , that was about the securing nut on wiper arms loose so hopefully you are right and my nuts are loose ( excuse the pun) will check in morning , fingers crossed ... Thanks again I said I wouldnt buy another one ! |
Surely it would be unusual for both wiper arms to become loose on their spindles at the same time and to the same extent ?
Anyone no how the plastic cover comes off across the bottom of windscreen to reveal the motor and rods ? I said I wouldnt buy another one ! |
Funnily enough just looked this up as I'm changing my faded warped one as soon as the new one turns up |
Cheers Paddi , will be ripping that off tomorrow to see what I can see |
Back again , plastic cover at bottom of windscreen came off easily to reveal wiper motor and rods , removed wiper mechanism and took motor off the rods , motor works ok . On further inspection of the mechanism ( not motor ) the near side had completely seized . Because I had not used car for a few weeks even then maybe no need to use wipers it looks like rain water runs down n/s wiper shaft and on to the mechanism below causing the shaft to rust . So if like Paddy you remove the plastic cover to renew it make sure you grease any moving parts on the wiper mechanism while cover is off . Have orderd complete wiper assembly including motor ( could not find mechanism on its own ) used part sourced on ebay will be here tomorrow .
Thanks Anders; that was a top tip |
