| RRSPORT.CO.UK | ||
|  | Home > Technical > Car is going crazy is it a Battery issue !! |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163      | Almost all systems communicate through the instrument cluster/assembly and if the battery voltage is low this will cause the 'Christmas tree' effect with the warning lights.
|  Sat Nov 09 2013 7:44pm |
| jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15    | Iv just replaced it with new battery so why would I need to charge battery
|  Sat Nov 09 2013 7:45pm |
| jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15    | Iv just seen on net that I may need to take it to Landrover to get re coded what's your thoughts ? | ||
|  Sat Nov 09 2013 7:47pm |
| Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 249      | If it was all fine before replacing steering wheel, have you put it back together properly?  What was the reason for replacing steering wheel? 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
|  Sat Nov 09 2013 10:00pm |
| jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15    | Yes tried replacing it with old one makes no difference ! Replaced it because I got new one from Kahn | ||
|  Sat Nov 09 2013 10:03pm |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | Nothing needs recoding, are you sure the new battery is fully charged, unless the wiring is wrong just changing the wheel should not cause any problems.. try a hard reset and see if that fixes it, and also what is the alternator pumping ot volts wise..
|  Sat Nov 09 2013 10:14pm |
| jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15    | Hi flack
|  Sat Nov 09 2013 10:26pm |
| jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15    | Flack what's hard reset ? Taking battery leads off tap them together and then re attach ? | ||
|  Sat Nov 09 2013 10:28pm |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | Yes thats it, but if you are getting that error code about bcm it has some how corrupted something, I think you might need to sync the ipack with the bcm to get rid of the error. The only thing I can think of is the battery was low when you reconnected it and this caused your problem.
|  Sat Nov 09 2013 10:44pm |
| jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15    | Cheers flack I'll take it to Landrover and see what they say | ||
|  Sat Nov 09 2013 10:49pm |
| Ferrar Member Since: 17 Nov 2013 Location: Salisbury Posts: 2      | Hi Jonny
|  Mon Nov 18 2013 7:17pm |
| Posting Rules
 t was down on volts so I replaced battery with new one and still my car is doing some crazy stuff can anyone point me in right direction to fix problem .?
