Home > In Car Electronics > Range Rover Sport 2006 - Loss of sound completely
jason-nike
Hi All
Recently stereo has decided it doesn't want to give out any sound.
Radio is working, cd player works, but no sound at all.
It also seems to freeze the sat nav on the Land Rover screen.
I have removed the cables under the seat which feed into the amp, cleaned all connections.
The only thig I can see wrong is the fibre optic cable is only showing 1 side lit up red.
Is this the problem?
What is the cure?
Any suggestions welcomed
Thanks in advance
Jas
Post #401508 Fri Nov 08 2013 10:45pm
tanloverluke
I searched on google for you and found this http://www.disco3.co.uk/forum/topic30520-15.html Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #401517 Fri Nov 08 2013 11:41pm
tanloverluke
Before my current job I used to code websites, in google its all about keywords, my search pulled up lots of results:
https://www.google.co.uk/search?q=range+ro...p;ie=UTF-8
I suppose I could change the word "working" to "work" but hey... Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #401518 Fri Nov 08 2013 11:46pm
chRRS
2009 Range Rover Sport TDV6 HSE Stornoway Grey
Mine did this and it was because I'd left the fridge on for weeks and it had gone into low power mode. Turned the fridge off and hey presto the volume returned.
Post #401565 Sat Nov 09 2013 4:57pm
flack
Try a hard reset that works most times if it does not then it sounds like one of your modules is playing up..
Flack Thumbs Up
Post #401568 Sat Nov 09 2013 5:20pm
jason-nike
Hard reset. you mean as disconnecting the battery?
Post #401609 Sun Nov 10 2013 8:36am
flack
Yes bud this way
http://www.disco3.co.uk/wiki/Hard_Reset
Flack Thumbs Up
Post #401613 Sun Nov 10 2013 10:38am
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Hi mate- I've got exactly the same issue. Did you have any luck with the hard reset,
Post #401730 Mon Nov 11 2013 8:37pm
jason-nike
Someone said to push the tuning button on the in until it displays reset (or something like that)
Tried that and the radio seems to work a lot better now.
Will see how things go
Post #401848 Tue Nov 12 2013 6:32pm
Bladeboy
And that's fixed your sat nav and volume issues?
Post #401852 Tue Nov 12 2013 6:48pm
jason-nike
Strangely it seems to be working.
Coincidence??
Post #401855 Tue Nov 12 2013 6:53pm
Bladeboy
When you say the tuning knob- you mean the one on the right like the volume knob- has had no effect on mine if that's the one.
Post #402000 Thu Nov 14 2013 12:21am
jason-nike
Yes that one.
Pushed it in for about a minute.
Radio been fine ever since
Post #402001 Thu Nov 14 2013 12:26am
Bladeboy
Thanks mate-.will try again as I don't think I held it for quite that long.
Post #402002 Thu Nov 14 2013 12:36am
jason-nike
Stereo intermittently works for a few minutes then goes silent again.
Sat nav wont work then either.
All stereo works but no sound.
Post #423639 Thu May 08 2014 9:18am
