![]() | Home > Maintenance & Modifications > Remapping somerset/dorset area |
I'm not sure your vehicle has a DPF fitted. |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Yours won't have a DPF and the EGRs can't be removed on RRS 07> onwards. 2014 L405 SDV8 RR Autobiography |
Adsgrey Member Since: 02 Aug 2013 Location: Somerset Posts: 6 ![]() ![]() |
Ok, that saves time and money then , cheers.
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
I would recommend Bell Auto Services in York, yes I know York is the other end of the world from you but you will get a first class job, not a 10 minute fiddle with a lap top.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
If you're just going to get a remap done (the EGRs can't be blanked and you don't have DPF) then just buy a BAS remap unit. The new map is sent by email and the whole process is fairly straight forward. 2012 SDV6 - it's missing a couple of cylinders
Cheers for the info I will look into it. |
Rossc77 Member Since: 08 Mar 2013 Location: Yeovil Posts: 4 ![]() ![]() |
Where' abouts are you matey Rudkins near Crewkerne in somerset can offer remaps |
I'm about 20 mins from there ill have a look, cheers. |
tonytiger Member Since: 14 Sep 2013 Location: St.Neots. Cambs Posts: 308 ![]() ![]() ![]() |
Hi I can't recommend Alive Tuning highly enough, I believe he now has somewhere in reading that will it his recaps, a little trek I know but tbh you need one based on recommendations |
The 90 on 20inch RRS wheels looks terrible. Just horribly wrong.
Hi in YouTube search "alive tdv8" it's the first one at the top
