![]() | Home > Maintenance & Modifications > 2007 tdv6 timing belt guidance |
| Rsdave137 Member Since: 26 Jun 2013 Location: Lancashire Posts: 44
Hello everyone
| Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289
7 years or 105,000 miles
Thankyou will do |
Had many prices on replacing timing belt
Have to echo what Steve, above has already said.
| Graz Member Since: 22 Apr 2013 Location: Essex Posts: 104
That's cheap. Down here the best price I had for service and belts was £712 at an Indy and the most was £1,200 |
Hi, just booked car in at local landrover workshop for timing belt replacement
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
On your year of car its a big YES to change the Oil Pump casing.... read these posts it will give you nightmares..
Thankyou |
| Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245
Just picking up on the timing case question. I have a 2005 2.7V6. I am preparing to do the cambelts shortly, but is the housing ok on these earlier engines?
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Check on your service book, you may well find that the rear belt was done under the HPFP recall, In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Recall Ref:
2005 models (and 2006) oil pumps are fine. HPFP recall was only on EU4 engines |
Brilliant, thanks.
| All times are GMT |
