![]() | Home > General > Tdv6 engine failure |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4479 ![]() ![]() ![]() |
First port of call is to check the oil filter has been fitted correctly |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
Ouch |
r4_rick Member Since: 18 Aug 2013 Location: Northampton Posts: 15 ![]() |
Turned out to be a new short engine ouch ! Apparently only one of the pistons was still connected to the the crank. I'm told the new block is supplied with the crank from the 3 litre engine which is much stronger.
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
Did you find out what caused the engine to go bang ? and im assuming it was originally a private sale if you had to pay for this after 8 weeks |
Yep private sale
As disco_mikey said it could have possibly been a badly fitted oil filter and the time scale since having a service and going bang could possibly be down to that maybe |
If it was at my local garage around the corner I'd have checked this out thoroughly, but it's a specialist whom I trust. I know the lads in the workshop, they know their stuff. |
ok if you can trust them |
No it was registered December 2005, |
