Home > Technical > suspension set-up
roberto.w
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
suspension set-up
Smile Hi,
I am new to this site,so hope someone can help me.
I have recently sold a high mileage 2006 disco 3,and bought a 2005 RRS with 42k on the clock and FLRSH.
I am very pleased with it,except the suspension is a lot harder,is there a different set up?They are both air.
If so can you please tell me the difference,and would it be possible to go back to the disco type suspension.
Many thanks in anticipation!!!
Post #400091 Sun Oct 27 2013 4:32pm
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Sport suspension differs from D3
its harder and much better quality
so no you can not have d3 suspension again Big Cry
on the other hand it shouldn't be as bad
so i would recommend to read faults and check if its faultless
if the hard feeling is not caused by some fault in EAS Thumbs Up
Post #400092 Sun Oct 27 2013 4:48pm
Paddi
Welcome Roberto. It may sound silly but have you checked the tyre pressures? My RRS was a bit harsh when I collected it but it was because some halfwit had confused psi with bar and massively overinflated the tyres.
What wheel size do you have? For comfort you need the smallest recommended diameter with the highest recommended tyre profile. Makes a big difference. These I think are 18 inches and 65 profile. Some folk on here run 22 inch wheels with skinny tyres but they must just love having their fillings replaced regularly. 2008 MY Java Black TDV8 HSE
Post #400096 Sun Oct 27 2013 5:14pm
mse
Many of the new land rovers have that now, bigger profile tyres...makes for a better ride. Mike
2014 Facelift Discovery
Post #400100 Sun Oct 27 2013 5:25pm
Disco_Mikey
You can go back to D3 suspension arms/bushes, but they will not last as long on an RRS. Don't really last long enough on a D3 Rolling Eyes
The RRS has a smaller profile tyre, compared to the RRS too. You can go up a size to match that of the D3 if/when you need all 4 tyres replaced Thumbs Up
If you have bought an RRS with the DR system, this will also make it seem firmer, as the ARC units try and keep the body level.
All little things that add up to a "sporty" ( Wink ) drive. That said, start with the basics of tyre pressures and so on Thumbs Up
Post #400193 Mon Oct 28 2013 7:28am
