![]() | Home > Maintenance & Modifications > Range Rover Sport Servicing |
At £205 thats not going to give your sport a good service |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
Alarm bells ringing at that low price |
I'd make sure you get genuine LR oil filter as non gen ones can cause issues if they twist in situ.
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Is this for a 5 or 6 year service? 2014 L405 SDV8 RR Autobiography |
Work it through like this, oil filter (genuine) £10-£20 depending source. Oil, 6l (8 bought to give required), correct spec castrol £45 cheapest none retail, new sump plug £6 air filter (genuine) £10. So before labour £70-100.
karan538 Member Since: 30 Oct 2012 Location: uk Posts: 89 ![]() ![]() |
Thanks for the idea of the prices, before they pick it up they will tell me what garage it is going to so I think I'll call in before it gets picked up to see how much they might charge roughly. Now I know to challenge there prices if they quote anything stupid
Some of these places make me laugh, with modern diagnostics, and if you know your product you don't need a sheet of paper to tell you what to look at. I was using check sheets like that 40 years when I was servicing about 4 cars a day, and believe me there was a lot more to service on the old cars than the modern ones of today.
Just pay the extra and get it serviced by a proper LR specialist, and not some back street garage that they probably use.
Its not to late to change your mind karan538 |
The thing is - quality parts (i only use genuine and/or the high spec brands all at the correct spec) aren't actually that expensive. As an example, I have loads of genuine oil/fuel filters in the garage - fuel filter genuine i think is £11, pattern part is maybe £7. Genuine is a known product, with 12 month warranty and only £4 more.
Recently had 60k Service done at Main Dealer cost £590.00 with Vat. included MOT, Re-Gas and Service Air Con. plus Renew Brake Fluid also included Collection and Delivery of car. Didn't think that was to bad a price.
Appreciate the feedback!
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
Which dealer was this?? I wouldn't mind the same done! 07 TDV8 + BAS map |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Buy your own parts, and give them to the garage to fit. That way, you know what has been done, and you still get a stamp in the book, but you don't get your trousers pulled down over the price |
