![]() | Home > In Car Electronics > range rover sport doesnt have satnav in it help |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Would suggest the hassle of this not worth it, the Landrover stat nav is not the greatest in the world and many find the lack of speed cameras a pain. You will require more than wiring as needs ariel too.
You would need a Touch screen, Sat nav DVD unit, some MOST cable plus the wiring harness and the plugs to in to all the units, a GPS aerial loads of patience and some one to install it all, plus you will need to get all the items fitted enabled in the cars CCF so the car knows there are fitted.
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
Get an aftermarket double DIN headunit, Pioneer or simular, that way you will have sounds,Sat nav, DVD, blutooth etc.... possibly the best and cheapest option for you, |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Too much work involved. You are better off retrofitting an an aftermarket unit. 2014 L405 SDV8 RR Autobiography |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Smartphone, windscreen mount, power from the cigar lighter. Simple and effective. Also it's up to date and includes scameras. 2012 SDV6 - it's missing a couple of cylinders
jw Member Since: 23 Aug 2011 Location: Lancs Posts: 34 ![]() |
Have an SE so no sat nav in mine , but my phone its a samsung note 2 ( yes it is a BIG phone lol ) but fits perfect in the place where the sat nav would of been , and the samsung nav app is fantastic , use it all the time |
