![]() | Home > Technical > Suspension noise |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
From the stealership? |
This is unjustified. So let's get a little balance in this:
I emailed danroberts[at]duckworthlandrover.co.uk which was the address he posted himself on the mat topic.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
I found Duckworths to be as good as Paddi says on the occasion I bought something from them. 2012 SDV6 - it's missing a couple of cylinders
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 ![]() ![]() ![]() |
I have bought a few bits from Dan and never had a problem. Always found him responsive with enquiries and parts have always been shipped as agreed. I used the PM facility on this site as opposed to emailing. Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone) |
Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Spoke to Dan at Duckworths who checked which parts I needed against my VRN, then sent out the bushes and clamps as requested, happy with the service. I'll update on knocking noise once the new bushes are fitted. |
OK, finally got the bushes fitted. No more knocking noise!! Easy job (though the fitter in work did it for me, with the use of a ramp), made easy by the use of a swan-neck spanner, meaning the only other bits to remove were the gearbox tray and fuel cooler. Total cost was about £25 for bushes and brackets, and a £10 for a drink to the fitter..... |
Think that's what is known as a result |
at that price you'll have a convoy heading towards Hereford |
Need to update my location, not there anymore.......it really was pretty straight forward though when you remove the tray and use a 'swan neck' spanner for the bolts...I reckon half hour in total if you were in a hurry |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
tony666. did you have a bang cluck when you drove at sat 10mph then jab'd the brakes on? |
No, I carried out the test as recommended by Disco Mikey but no clunk at 10Mph test. What I had was a slight knocking noise over small bumps, uneven road service or small pot-holes. It didn't take much to cause the knock, but now all sorted. Hope this helps...... |
ok thanks |
