Home > General > FUZE for trailer/caravan problem
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
I have a 2009 Sport. I have been having problems with the car battery running to flat when parked up for a couple of days with the caravan electrics attached. In boot there is the small 'bank' of fuzes relating to the toe connections - I presume if I take out the fuze that is the live 'battery connection' there is not possibility of the caravan being able to take power from the car battery? Or am I missing some thing! Andrew Kennedy
Post #397980 Fri Oct 11 2013 3:43am
Does your caravan not have a selector switch? To use the onboard caravan battery or car battery?
Post #397982 Fri Oct 11 2013 6:58am
simple1
You have a fault somewhere in your charging system for caravan or white plug. There is a relay that prevents power going to caravan unless there is over 13 volts in car system ie when it's running. If you run your fridge on gas, you will greatly reduce the drain if you have to leave the connected over night. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #397984 Fri Oct 11 2013 7:11am
Why are you leaving it connected over night Question Confused
Post #397988 Fri Oct 11 2013 7:54am
Martin
Site Administrator & Owner
There is a permanent (not relay switched) feed to the tow electrics - removing the fuse could help you track down the issue but you should fix the reason for the drain rather than use that as a permanent solution Smile Like this site? Buy some RRSPORT goodies to show your support!
Post #397991 Fri Oct 11 2013 8:49am
Martin
There are both a permanent and switched 12V supply. Like this site? Buy some RRSPORT goodies to show your support!
Post #398039 Fri Oct 11 2013 2:28pm
Cupra
depending what you have fitted most systems should switch off the fridge and 12v feed with the ignition, ive a smartcom fitted to mine and ive never had a problem
Post #399067 Sat Oct 19 2013 8:26pm
