Home > Faults & Fixes > Catalytic convertor replacement on RRS SC
Tigerdon
Northern Ireland 2006 Range Rover Sport Supercharged Java Black
Ok guys update on mine
Took truck from my house in NI to Dublin approx 110 miles
Car travelled down With no problems
Coming home today, approx 20 miles out of Dublin went to overtake a row of cars, When I went to accerlate I noticed same thing as before, ie she seemed to clog up slightly then it went but the engine management light came on
I nursed it up home at approx 70mph whole way and took it straight to my friend who has diagnostic checker
Exact same 2 codes 420 and 430
P0420 Catalyst efficiency is low, Bank A (NAS only) Y C
P0430 Catalyst efficiency is low, Bank B (NAS only) Y C
All cats are outta the truck on both banks, they were cut open with internals smashed out and spacers installed on the lambda sensors
Can anyone please advise me what else could possibly be causing this as I'm losing will to live.
Post #397422 Sun Oct 06 2013 6:42pm
Tigerdon
Also guys mabye I should say also about a slight roughness engine idle. It's only slight between 250-500 rpm approx 4-5 times when u apply light pressure to accelerator when stopped and again when u come to a junction for example and stop before pulling out
Although my mechanic says this is a base idle issue
It's not revving highly or stalling
Thanks
Post #397423 Sun Oct 06 2013 6:50pm
Disco_Mikey
At the risk of stating the obvious, the Catalytic Convertors are missing on both banks, so the lambda sensors will not be reading correctly. You need to rectify this, before looking any further into the issue
Post #397426 Sun Oct 06 2013 8:26pm
Tigerdon
Yes mate but the Lambda spacers are meant 2 sort that aspect of it out. Ie they trick the computer into thinking readings are ok and in theory the EML never comes back on
It's my understanding this happens when road cars are made in track cars and de cat done
Post #397436 Sun Oct 06 2013 9:02pm
Disco_Mikey
You answered your own question. In theory...
That's what is meant to happen, but it is a sophisticated management system, it may not work on the S/C Sport...
Post #397444 Sun Oct 06 2013 9:34pm
Tigerdon
Fink ya might be right
Tell me this would egr be causing that slight problem I'm having with rough base idle
Ie car just taking 4-5 revs before finding its base?
It's not really rough generally not going above 750rpm
Post #397450 Sun Oct 06 2013 10:24pm
