![]() | Home > Maintenance & Modifications > LED Lighting |
HICKY555 Member Since: 27 Jan 2013 Location: WORCESTER Posts: 208 ![]() ![]() ![]() |
ORDERED THE REAR BOOT INTERIOR |
I didn't forget it. I was unaware of it |
just ordered these to try VERY LOW PRICE
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Has any body upgraded the door mirror bulbs to LED? |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Did mine today- 11 of them. Very impressed. However, while I was doing the drivers side back door puddle light the wire came off and disappeared behind the door card. Is the door card a pig to get off? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9088 ![]() ![]() ![]() |
No, the door card is a pull off item. You need just pull off the bottom part.
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
have done 10 in mine,and the white light does look so much better. changed the usual, going to buy a few more now to finish off. any left overs i'll put in the wifes Fiesta ! |
Thanks for that- will pull it out tomorrow. Ordered another four for the glove box,number plate lights and a spare. Just seen them for the first time in the dark- what a difference for about £11!! |
Be aware |
Ok- thanks mate. Any tips on how to avoid cracking them? |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
just ordered the set of 10 to begin with, many thanks for the tip |
They do crack really easily. After breaking one of mine - found it is better to remove the upper tailgate trim and then you can get at them from inside and see what you are doing. Video on how to do it; Whilst you are there it gives you a great opportunity to clean up and seal the notoriously troublesome upper tailgate switch just in time for winter. 2008 MY Java Black TDV8 HSE ![]() |
dcartner Member Since: 04 Oct 2013 Location: West Yorkshire Posts: 31 ![]() ![]() ![]() |
Any help on changing the number plate bulbs to LED, got the bulbs, however when we eventually got the casings out, the wires were far too short to 'twist' the bulb holder free?
Kenzi Member Since: 24 Jun 2013 Location: Perth Posts: 101 ![]() ![]() |
Either your on commission or they wasn't £54 when you ordered them?! |
