| RRSPORT.CO.UK | ||
|  | Home > Technical > Electrical issue - Drivers seat, drivers door lock & mir |
| finbarfinnegan Member Since: 26 Aug 2011 Location: Banbridge Posts: 19      | Had a moment of clarity and went back to the fuse box.  There are multiple fuses for each seat and after a review of ALL the fuses that cured 2 of the problems - one was blown and now the seat and mirrors are OK again.  But the drivers door lock still isn't locking.  It doesn't make sense as when I lock it manually and then lock the rest of the car on the button, it will unlock on the other button. Defintiely not a fuse (I pulled a lot to check and double check) I guess the next step will be taking the door card off and looking into the depths to see if the mechanism is broken.  | ||
|  Tue Sep 24 2013 2:08pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Probably your driver's door latch mechanism is faulty. There are two little electric motors one to lock and one to unlock. The locking one gets weak. Easiest fix is to buy a new latch from Duckworths and fit it yourself. A bit fiddly but if you take your time and follow the instructions here:
|  Tue Sep 24 2013 2:19pm |
| finbarfinnegan Member Since: 26 Aug 2011 Location: Banbridge Posts: 19      | Thanks for the info Paddi - I'll have to make do until I can get the time to have a go.  More pressing issues at present - like my timing belts and lower wishbones at the front....  Car still locks when I use the "manual override"!
|  Wed Oct 02 2013 3:56pm |
| finbarfinnegan Member Since: 26 Aug 2011 Location: Banbridge Posts: 19      | Well - I don't want to jinx the bloody thing, but the door started locking again all by itself!!  I did nothing other than operate it manually for a few weeks (pushing the lock cloed in handle befor closing and locking the car with fob)
|  Fri Nov 15 2013 2:46pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Good news on the door latch then. The motors don't die completely - they just get a bit weak owing to brush wear so its possible operating it manually loosened things up enough for it to work; for now.
|  Fri Nov 15 2013 4:29pm |
| finbarfinnegan Member Since: 26 Aug 2011 Location: Banbridge Posts: 19      | Hi Paddi
|  Thu Nov 21 2013 3:22pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Thanks for the update Tim.
|  Thu Nov 21 2013 4:37pm |
| Posting Rules
